Lowering HHR...Week 1 Update
Old Apr 10, 2006 | 02:34 PM
  #71
ng8650's Avatar
Use German Torque:
Goodn'Tight...
Ng
Old Apr 10, 2006 | 02:48 PM
  #72
SoCalHHR's Avatar
And re-check them often!
Old Jun 13, 2006 | 01:59 PM
  #73
SCOOT's Avatar
Thumbs up Thank You!!!
Originally Posted by dan-d
Not much to see, hope this helps. Sorry for the blur, my camera skills aren't the best. -Dan
All installed - keep in mind that you can't see the cam on the bolt, but it is facing inward toward the center of the car. You also can't see the small tab and it's facing inward also.
Just wanted to add my ...
I recently swapped my stock springs with the GoldLine variety using other threads on this site (Thanks NG) and wanted to give a big to Dan-D for providing the info (and pic's) on the Camber Bolts (thanks to Mike for seeing to it they got to me!!!). It really helped alot!!! Believe it or not... bolt arrows pointed in (toward engine) and tabs pointing out (toward tire) left the camber IN SPEC!!! Put about 180miles on the springs and ended up getting aligned last night... I couldn't believe it was in spec!!!
Thanks again Dan, NG (and ALL)... for the input and feedback re: lowering. Your in my book!
FYI- garage install on jackstands took 2.5hrs (2 people)... and we're both only weekend warrior mechanics (but I do have air tools).
jalli008
Mar 7, 2013 07:46 AM
Sneezy
May 19, 2008 09:14 PM
Doc brown
Apr 15, 2008 07:34 PM
longhorn
Aug 30, 2006 10:35 PM
