Moog problem solver control arm
Old Nov 11, 2019 | 10:58 AM
vcrpro3's Avatar
Question Moog problem solver control arm
Per the subject line, has anyone used these? Are they(stamped steel) the same geometry as the cast aluminum arms? Any handling improvement noticed?
Old Nov 11, 2019 | 11:02 AM
The steel control arms have never been recommended on this site.
Old Nov 11, 2019 | 11:46 AM
The Moog PART NUMBER: MOOG-RK620897 and RK620898
are the ones to order
https://www.moog-suspension-parts.co...rolet_hhr_2009
search the RockAuto site and don’t forget the discount code
https://www.chevyhhr.net/forums/supp...-2020-a-61707/
Old Nov 11, 2019 | 11:47 AM
Rocket Dawg's Avatar
I used them, they are nice.
Old Nov 11, 2019 | 11:50 AM
I prefer to rebuild existing LCA’s with
Front Lower Ball Joint
PART NUMBER: MOOG-K80567
and 2
Front Lower Rearward Control Arm Bushing
PART NUMBER: MOOG-K201285
Old Nov 11, 2019 | 02:33 PM
HHR was never designed for the steel control arms, no version of the HHR was ever produced with steel control arms.... Should be enough of a clue to not use the steel control arms on an HHR.
Old Nov 11, 2019 | 02:56 PM
vcrpro3's Avatar
Moog Problem Solver
How long ago did you install them?
Old Nov 11, 2019 | 02:59 PM
vcrpro3's Avatar
Any shop i have contacted refuse to do bushing replacements on those control arms. They want to use new control arms.
Old Nov 11, 2019 | 03:04 PM
They are scaredy cats! Some idiots are afraid to use a press on Al alloy; that is why there is a tool made for the job; basically a piece of all thread with a cup on one end and a press out on the other.
If it is the unlike metal thing they fear Moog makes one with the proper coating for alloy.
Old Nov 11, 2019 | 03:05 PM
Why do they refuse? Don’t have a press ?
I posted the Problemsolver bushing with the zinc coating part number.
