Moog problem solver control arm
Old Nov 13, 2019 | 08:18 AM
vcrpro3's Avatar
Originally Posted by Rocket Dawg
Yes aluminum and they look like very high quality.
Did they, in fact, come with the 'problem solver' ball and socket design rear bushing? The ones pictured in the Moog catalog for my 2008 model are specified as stamped steel. The cast aluminum have the standard rubber/elastomer sleeved rear bushing.
Old Nov 13, 2019 | 09:14 AM
The Moog LCA’s do not include the problem solver bushings in the above photo
Old Nov 13, 2019 | 10:03 AM
vcrpro3's Avatar
Originally Posted by Oldblue
The Moog PART NUMBER: MOOG-RK620897 and RK620898
are the ones to order
https://www.moog-suspension-parts.co...rolet_hhr_2009
search the RockAuto site and don’t forget the discount code
https://www.chevyhhr.net/forums/supp...-2020-a-61707/
The Moog P/N i'm looking are CK620301 and CK620301
Old Nov 13, 2019 | 11:58 AM
Don't you read? Those are the stamped steel ones - and yeah they may be listed as being for the HHR, but they aren't the right ones.
They probably will fit (as the platform is shared with the Cobalt), but will not be as strong as the cast ones (the Cobalt is a lighter vehicle).
Are we just wasting our times trying to steer you in the right direction?
Old Nov 13, 2019 | 02:07 PM
This has been discussed Oldblue found that initially the bushing offered by Moog had a steel wrapper for steel control arms; they later came up with the same part with a zinc (I think) coating to be used for the alloy arms.
There is a very small worry that unlike metals can cause a corrosion problem. I don't think the LCA will last long enough for that to happen.
The Moog catalog is in no way definitive and sometimes completely wrong.
Old Nov 13, 2019 | 03:19 PM
  #26
Yes, and don’t get me started on corrosion problems, I live in the snow belt / rust belt of southern Ontario, Canada.
the steel arms are cheaper and for the Cobalt , not the HHR!
Old Dec 29, 2019 | 02:46 PM
  #27
vcrpro3's Avatar
Recent update. I checked with a couple of auto machine shops..Even they will not replace just the bushings if i bring in the original arms.......WTF??????
Old Dec 29, 2019 | 03:15 PM
  #28
Go to your local chain auto parts store and get a kit. I have no idea why a shop can't do it. I know it is simple to do.
I think the tool would be a ball joint press. You might need to get 2 kits and mix 'n match the cups to fit.
"Press" does not mean hydraulic press a simple screw press is the thing.
Old Dec 29, 2019 | 03:59 PM
  #29
Cat Man HHR's Avatar
Yes the tool is a ball joint press.
I know Auto Zone rents this tool for free.
This is for Cobalt (same thing) at the 10:50 mark you can see the tool being used.
Old Dec 29, 2019 | 10:08 PM
  #30
Another method
https://www.suspension.com/blog/how-...thout-a-press/
I don’t know why a mechanic would decline the job .
perhaps a machine shop in your area?
