My front end clunking, is there an echo in here?
Old Feb 27, 2018 | 04:43 PM
That’s correct they have a new zinc coated bushing, that new part number is in the RockAuto site, I’ve had the non zinc coated bushings in place now for a few years, no corrosion
Old Feb 28, 2018 | 05:33 AM
Cat Man HHR's Avatar
Originally Posted by Oldblue
Cat Man HHR, all HHR’s came from the factory with cast aluminum LCA’s , not stamped steel, if yours had stamped steel it was because someone put in the inferior cheap offshore ones.
The Colbalt and Pontiac G5 came with the stamped steel LCA’s, with the four lug hubs.
Thanks for the correction. All this time I thought there was two different ones for the HHR.
Old Apr 2, 2018 | 01:37 PM
skyline26's Avatar
if you swap out the bushing with the moog "problem solver" bushing...should we change out the balljoint and the lower bushing also?
Old Apr 2, 2018 | 03:21 PM
If you want to.
Old Apr 2, 2018 | 04:20 PM
I'd only change them if they need it.
That front bushing doesn't get much wear from what I saw. I had to replace one of the lower ball joints as it got some water in it and started to show visible rust dripping from the rubber boot - yup - sloppy and total worn out.
Old Apr 2, 2018 | 04:44 PM
LCA rear bushings and ball joints , yes, that front bushing seldom wears out.
DaveB
16
Dec 18, 2010 10:11 AM
DanH
Oct 5, 2010 01:41 PM
whiteyHHR
Jun 19, 2010 01:44 PM
3amigos
Jan 8, 2009 09:50 PM
HHR-VTX
Jan 7, 2009 10:58 AM
