new rear shocks.
Old Mar 18, 2010 | 12:42 PM
xpeppyx's Avatar
new rear shocks.
hey i need some advice. i took my car tot he shop to have some work done on it. and they say i need new rear shocks. and its going to cost $300 for parts and labor. is that a decent price?
Old Mar 18, 2010 | 01:34 PM
HipHotRod's Avatar
Unless he is selling shocks for $125.00 each something's not right. Rear shocks on our cars are very easy to replace. Wheel comes off - bolt on top and bottom of shocks. Pretty simple and can be done with basic tools.
Old Mar 19, 2010 | 03:37 PM
xpeppyx's Avatar
yeah just went and bought a pair of shocks. got 1 1/2 on. then stripped a bolt so waiting for girlfriend to get here to go to lowes and find a new bolt. or the junk yard to get it for $10... damn con men..
Old Mar 19, 2010 | 04:17 PM
lunchbox's Avatar
hey, make sure you keep an eye on that stripped out bolt. i did the same to mine, and it worked it's way out three times while i was driving. kinda scary when you're cruisin and the bottom falls out. i ended up drilling out the mounting hole, and putting a longer bolt through with a nut to hold it in place. good luck man, later.
Old Mar 19, 2010 | 05:03 PM
xpeppyx's Avatar
ill keep that in mind. thanks
Old Mar 19, 2010 | 07:53 PM
1Panel2NV's Avatar
Put a floor jack under the rear beam so you can line it up with the shock. That should help prevent cross threading.
Old Mar 19, 2010 | 10:25 PM
^ X2 ^
& If you are concerned about the stripped one, get a longer bolt, long enough to put Nut on the end & use Loc-Tite..
1Panel2NV-
Sharp looking new ride man !!!
Old Mar 19, 2010 | 10:29 PM
THE BATMAN's Avatar
Is this the new ride, A cobalt NV ? What's up kendell ? It was still mt fav panel.
Old Mar 25, 2010 | 06:16 PM
katarn's Avatar
Does anyone have a how-to or maybe some pictures of changing out the rear shocks. I too was told I needed to replace the rear shocks in my HHR.
I was only quoted $180 though.
Also, does anyone have a recommendation as to a good brand that isn't too pricey. Thanks
Old Mar 25, 2010 | 08:11 PM
fringeIT's Avatar
There's a Sticky in the How To section.
