P0561 traction control
Old Oct 9, 2022 | 08:29 PM
flstss's Avatar
Crud in the area of the sensor can cause trouble. I imagine that would include an intermittent signal. There is a TSB on it. The fix is to remove any dirt or foreign objects.
The intermittent signal is no longer, it did that before I change the hub. Now it's perfect the only problem is I get the code C 0561, the other three codes I got before I change the hub was c0460 c0161 and c0035.
Old Oct 9, 2022 | 09:41 PM
Have you tried pushing the Traction Control button?
Old Oct 10, 2022 | 12:37 AM
PulpFriction's Avatar
Brake signal? Steering position? OldBlue may have been barking up the right tree with weak battery/power. Has the car ever had the power steering motor replaced under the recall or warranty? Sometimes the bad motors cause trouble by drawing excessive current. How old is the battery? You could load test it as well as see if it’s holding voltage and while it’s out, maybe the hard reset will make a difference.
Old Oct 10, 2022 | 08:42 AM
flstss's Avatar
Yes
Old Oct 10, 2022 | 08:45 AM
flstss's Avatar
The battery is relatively new about 2 years old. Power steering motor never replaced.
miles solo
May 23, 2022 06:41 AM
Mark9724
7
Aug 7, 2021 09:09 AM
gio89kid
Feb 17, 2015 08:15 PM
Speedrazer69
Jul 29, 2013 11:31 AM
Supermode
Jul 9, 2008 01:16 PM
