Question about the ZZP rear sway bar.....
I have one. You can get them at local shops too. Its a good improvement on the road to reduce body roll. It tucks up into the rear beam so ground clearance isnt reduced.
If you are into driving fast, track or auto-x, you might want a stiffer bar, like powell hardcore or xxx.
Others on here like the TTR, but I havent tried it.
Yeah I've been researching nazgul and the progress is a 22mm or 3/4 inch rear where as the TTR is a 25 mm or 1 inch rear. The TTR is offered from turbo tech racing in our vendor section and it's priced better than even the cheaper ones on Ebay or Amazon. the xxx and Powell I believe are 1.25 or larger and may be a bit too large for street driving because this could cause snap oversteer unless you tune or swap your front bar also
I be running a Powell "Hardcore" 1 1/4" bar for a couple years now, and it does'nt do anything funny, even in the rain, on slick streets. The "Hardcore" bar would be about tops for the street and some track time, as the XXX bar borders on being just a little stiff, and in the rain could make the tail end a little happy. I'm more than pleased with the handing, and do a little autocross, and it works super dupper. Slot car cornering. "Moon"
DANSHHR
Apr 13, 2009 10:50 PM
