rear calipers dragging, fixed
So the other day I noticed my e-brake would not release entirely on my SS with rear discs. After pushing the button, the handle would fall and did not have any tension on the cables. My first thought was a seized e-brake cable. So I took the center console apart so I could see the cables pulling (or not). My right side was moving, but the left cable seemed seized. I use my ebrake all the time because my driveway is on a slight hill and I have a 5speed. Anyway, the issue could only be 1 of 2 issues- cable seized in its sheath, or my left rear caliper won't release. Jacked the car up, whipped off the left rear wheel to look at the caliper. The lever on the caliper where the cable mounts was seized solid. Tapped it with a hammer while spraying the pivot with PB Blaster. The lever unseized, and I could see the cable moving freely under the center console. So, the cable was fine, left caliper needed lubed. I shot the right side while I was under there and now my ebrake works fine and RELEASES fine.
Moral of the story is don't presume it's a seized cable. Took 1/2 hour taking my time and the only cost was 1/4 bottle of PB Blaster. Hope this helps others.
But I always try to work smarter, not harder. May take a little longer investigating, but will save time in the actual repair and saves money- usually.
David.Lister
Nov 8, 2015 06:36 PM
wzolla86
Jul 18, 2012 10:33 AM
