Rear shocks & Coil springs Replacement
Old Aug 11, 2018 | 01:16 PM
Judgered65's Avatar
How do I replace the rear shocks and coil springs on a 2008 HHR LT? Is there a video of some sort I can reference? Do I need to take it to a shop or can I do it myself?
Old Aug 11, 2018 | 01:32 PM
Old Aug 11, 2018 | 01:37 PM
Remove the 2 bolts holding each shock.
Take care with the brake lines, disconnect them if needed.
remove the shocks
Pry the trailing arm down and remove the springs.
You will probably need new jounce bumpers and isolators for the springs.
Old Aug 11, 2018 | 02:01 PM
Yes, you must remove the bolts for the brake lines
Lower shock bolt removed
The bracket, one on each side!
New springs back in place!
Drifter..
7
Feb 22, 2018 07:19 PM
RatRodS
Jul 10, 2015 02:30 PM
Patrickh60
7
Jun 21, 2013 01:59 PM
