Replacement brake rotors.
Old Apr 4, 2008 | 04:03 PM
Goose's Avatar
Jesse- Did you install yourself? Difficulty?
Goose
Old Apr 5, 2008 | 12:18 AM
JoeR's Avatar
Goose
No he didn't.
Easy job. Two bolts to remove the caliper, two more for the caliper bracket. Swap the rotors, put the bracket on, then one caliper bolt. Compress the piston, swap the pads, rotate back into position and put the last bolt in. Done.
Old Apr 5, 2008 | 06:43 AM
JESSE's Avatar
Originally Posted by chadpuska
so its stops a lot better?
Much better. You can feel the difference.
Originally Posted by bigallis1
Just talked to Gregory at world performance parts. They are the distributor for the SP brake rotors and pads.
They have sold the SP rotors and pads to several dealers to be installed on HHR's, and have no problems.
I am considering going with them, unless someone can convince me the EBC product is just as good.
SP rotors are: $244.47
SP pads are: $54.11
How much are the EBC rotors and pads.
Your opinions please.
Check with or supporting vendor HHRBOUTIQUE, MY wife paid $279 for EBC rotors and red stuff pads from somewhere else....
Goose
No JoeR did most of the work. Having the power tools makes it easier. Took about a 1/2 for both sides!
Old Apr 18, 2008 | 11:58 AM
thedonn007's Avatar
I will have to look into these rotor as well. I will be needing by thrid set of rotors soon.
Old Apr 18, 2008 | 01:06 PM
jshandra's Avatar
I just purchased a set, waiting for the shippment to arrive this Monday. I can't wait to install,will keep you posted. I do plan on installing them myself...
Old Apr 18, 2008 | 01:51 PM
  #26
Goose's Avatar
Would love to see a step by step how to :)
Goose
Old Apr 18, 2008 | 10:35 PM
  #27
xzombiex66's Avatar
i also should be getting mine monday
Old Apr 19, 2008 | 07:20 PM
  #28
Todd TCE's Avatar
Former Sponsor
That black is what's call e-coat. This is very similar to powder coat but much thinner. It's becoming a more popular choice over the conventional zinc coatings due to better uniformity in finish and the issues of electro plating and chemicals etc.
Wilwood is now moving to this finish on many of the SRP drilled parts also. I'd like to consider it personally but have yet to find anyone in the Phoenix area who has set up a line to run this process....
rodder
Maintenance and Upkeep
15
Sep 21, 2013 08:14 AM
lionelgilbert
18
Mar 2, 2012 06:44 PM
Len Sholes
Sep 4, 2010 04:14 PM
TiggersHHR
Tires & Wheels
Mar 8, 2010 06:06 AM
hhrboutique
Jul 22, 2008 07:38 AM
