replacing struts
Old Feb 10, 2012 | 09:54 AM
dlmhhr's Avatar
replacing struts
it looks like it takes some kind of special tool to get the sway bar loose from the strut..it looks like the bolt is longated on the head..is this true..sorta kinda of a oval..any help would be great..changing them out in a couple of weeks.wish i would have seen about the monroe's qs..i hope it works out ok.....
Old Feb 10, 2012 | 12:12 PM
Rod Run's Avatar
It takes a regular wrench
Old Feb 10, 2012 | 12:37 PM
barfan1's Avatar
You have to hold the end of the link and then loosen the nut with a regular open end wrench. The link may have a recess to put a hex ended bit into to hold it from spiining or if you are replacing the link also(highly recommended) just use vice grips.
Old Feb 10, 2012 | 08:19 PM
alexrckid's Avatar
the stock sway bar links have a shallow(very shallow) set of flats(14mm, if i remember correctly) that allow you to "lock" the ball from spinning when you try to loosen the nuts....both top and bottom. a well fitting open end wrench is a must........along with an impat wrench on the nuts......this deal worked for me when i replced the stockers with moog links.......great move, by the way. also, the moogs have broad flats for an open end wrench.
Old Feb 10, 2012 | 08:26 PM
dr_fosg8's Avatar
For the end link removal, everything listed above plus I had to take the map gas torch to the nuts also. No impact here so the heat really helped break them loose.
Old Feb 11, 2012 | 10:49 AM
dlmhhr's Avatar
thanks for all the help..i hope the struts have the right springs in them..after what ive read on here about them..thanks again...
Old Feb 11, 2012 | 03:41 PM
And if you meant the bolts at the bottom of the strut that connect it to the steering knuckle. One side is a nut, the odd looking side is splined into the hole. You only need to hold it to keep it from spinning and doing damage to the bolt splines, or not.
Old Feb 11, 2012 | 09:49 PM
alexrckid's Avatar
ummm....MONROE quick struts..??
Old Feb 19, 2012 | 11:16 AM
dlmhhr's Avatar
called monroe about the wrong spring issue & gave them the numbers i had on the boxes,,the right one was fine, had to send the left back for replacement..glad i read on here about this problem before i tried to install..now i hope they work with no problems when i do install them...thanks for the info........
Old Feb 19, 2012 | 10:41 PM
dr_fosg8's Avatar
Well whatever you do do NOT throw out your OEM springs when you take off.the original struts. At least not.until you have put say, 100,000 miles on the quick struts. I have had the replacements already and the springs are not factory equivalents.
