replacing struts
Old Feb 27, 2012 | 08:25 PM
css9450's Avatar
Originally Posted by alexrckid
the stock sway bar links have a shallow(very shallow) set of flats(14mm, if i remember correctly) that allow you to "lock" the ball from spinning when you try to loosen the nuts....both top and bottom. a well fitting open end wrench is a must........along with an impat wrench on the nuts......
In the salt belt, those nuts are VERY difficult to remove. I got three of mine off only after holding the shaft very tightly with a vise-grip. The fourth one refused to come off because no matter how tight I made the vise-grip, the shaft eventually would spin and it would drop the vise grip. On that one, I eventually spun the nut all the way back on and used my angle grinder to remove all the exposed portion of the threaded shaft. Then the nut came off OK. I suspect the nuts are thread-deformed (or something) to resist unthreading. The nuts on the tie rod ends are the same way.
And yes, the Moog endlinks are wonderful with a nice, robust hex on it to hold it with a wrench.
Old Mar 3, 2012 | 10:56 AM
gguy1's Avatar
It is starting to sound like the springs on the Monroe quick struts are not that good?
SteveMaine
Oct 13, 2013 06:49 PM
emd820
Mar 20, 2013 11:58 PM
StockLT
Maintenance and Upkeep
Jan 26, 2013 06:47 AM
delta88
Jun 19, 2012 06:20 PM
zeevette
Oct 23, 2010 09:00 AM
