replacing struts
the stock sway bar links have a shallow(very shallow) set of flats(14mm, if i remember correctly) that allow you to "lock" the ball from spinning when you try to loosen the nuts....both top and bottom. a well fitting open end wrench is a must........along with an impat wrench on the nuts......
And yes, the Moog endlinks are wonderful with a nice, robust hex on it to hold it with a wrench.
