Simple Suspension Upgrade 2006 LT
Old Feb 19, 2011 | 12:15 PM
nbean's Avatar
I want to upgrade my '06 LT suspension, (FE1), with new struts, springs, control arms, front & rear sway bar. Please recommend vendors & parts as indicated above. Many thanks.
Old Feb 19, 2011 | 03:35 PM
1Panel2NV's Avatar
FE5 parts from CED except the rear sway bar (and possibly springs if you're looking for a drop). For the sway bar, Powell Raceshop.
I don't see the need for changing control arms though. The FE5's are aluminum, I don't remember if base HHR's came with steel arms or not.
Why are you wanting to do this?
Old Feb 19, 2011 | 04:21 PM
Rod Run's Avatar
Take a few minutes and do a search around the forum. You will find good answers to a lot of your questions
Old Feb 19, 2011 | 06:52 PM
BlackknighT's Avatar
Welcome by the way & keep enjoying your ride!
Old Feb 19, 2011 | 07:18 PM
Welcome and Greetings!! Spend some time poking about in the suspension threads here, you'll find lots of good info to go on.
Old Feb 19, 2011 | 09:35 PM
"The FE5's are aluminum, I don't remember if base HHR's came with steel arms or not".
FE3 control arms are aluminum also.. I also don't see a need to change those. But up to the OP..
Old Feb 19, 2011 | 09:38 PM
IgottaWoody's Avatar
Only reason is for new bushings...
Old Feb 19, 2011 | 09:47 PM
Woody- yep, that's reason enough to remove, I'd replace the oem bushings with Poly bushings..
Old Feb 19, 2011 | 10:46 PM
http://caddyinfo.com/wordpress/?p=6712
But then if we could crossbreed these parts.....
Old Feb 19, 2011 | 11:08 PM
That's impressive, would need to decrease the offset on the rims to clear, but not a biggie..
