SS Front suspension on a 2LT
Old Oct 12, 2009 | 12:44 AM
Snoopy's Avatar
Has anyone installed the SS struts on a 2LT? For that matter, does anyone know for sure if the SS struts will fit? Does this retro fit require any modification or is it essentially a remove and repair operation?
I have the rear SS springs installed already. And thought about replacing the struts as long as they are out when installing the SS front springs. I'm "contracting" with a guy to make a larger front anti-sway bar...expensive (I understand the SS bar will not fit because of engine clearance differences?).
Old Oct 12, 2009 | 06:48 AM
JoeR's Avatar
Not sure of the SS strut fitment, but they should be a direct and easy swap.
Front sway bar... The stock one is 25 mm. Why go larger? BTW, the front SS bar is actually smaller, 23 mm, if I recall correctly.
Old Oct 12, 2009 | 03:59 PM
1Panel2NV's Avatar
Are the sway bars sized differently than cobalts? I thought they got incrementally bigger from fe1.
Old Oct 13, 2009 | 03:02 PM
Marcruger's Avatar
It'll certainly ride harder with SS struts. If you add a fatter from anti-sway bar, you're going to increase relative understeer. I am not sure you are really after that. God Bless, Marc
Old Oct 13, 2009 | 03:53 PM
Snoopy's Avatar
yeah you're probably correct on both BUT.....
Harder ride is "in the seat" of the driver. Harder ride and to what degree, is subjective......my other car is a "harder rider".... I don't object and rather like it. I do not tolerate vehicles that 'tilt" into turns and corners and have poor to fair handling.
The understeer....maybe. Depends on what else I do to the rear suspension
Old Oct 16, 2009 | 12:27 AM
IgottaWoody's Avatar
..... and to think,it has nothing to do with being a race car! (like ive heard so many times). If I wanted tilt I'd by a full sized van!
afornal
11
Sep 22, 2012 02:20 AM
Doog47
Nov 7, 2011 02:58 PM
reelhhr09
Feb 16, 2011 04:26 PM
TomR00
Jan 6, 2008 03:16 PM
