08 HHR - Right Front Suspension Pics
Didn't know if anyone could use these pics for comparison to earlier year HHRs or not. Took these while changing my tires this afternoon. This HHR has the Sport Suspension option, shows the front stabilizer bar attach point, disc brake and front suspension.
TomR
TomR
I'm guessing at this, basically because of the way parts are listed on Parts Direct....
Nothing is different, on the 2006 at least, except the struts. If you try to order the Stabilizer bar, the springs..only one is listed . If you try to order the strut, it lists the 2 different suspensions for each side.
So, I would say the spring "weights" are the same.
