SS rotors on standard HHR
Old 09-22-2012, 03:18 PM
solman98's Avatar
Did this today. Straight forward swap. But the procedures are the same for just swapping rotors, same work would need to be completed. This is my method, yours may vary.
First, gather the parts you will need.
Here is a comparision between the standard HHR rotor and the non Brembo SS rotor.
Shot of the stock rotor behind the wheel. The Cobalt wheel has a large center plate.
You will need to raise the wheel off the ground, and support the car. Once you remove the wheel, this is the stock setup.
Before you dig in, seperate the two new caplier brackets. They are marked L and R.
Remove the 2 bolts from the back of the caliper and support it. I use a heavy gauge wire off the strut spring.
Then you can pop out the pads and remove the caliper bracket. Here is a comparision of the standard verses the SS.
You will need to transfer the hardware from the old caliper bracket to the new one. Make sure the caliper pins have plenty of grease.
With the caliper bracket off, the rotor will slide right off. Swap it with the new SS rotor and bolt on the new caliper bracket.
Before you install the new pads, be sure to install the wear indicator if the new pads didn't come with one. These didn't. It just snaps on. Then install the new pads. Mine had the wear indicators on the inside, so I put that pad back to the inside.
Before you can put the caliper back on, you will need to compress the piston back in. I use a 4" C-clamp and one of the old pads. Yes I saw the rubber material on the caliper. It's looked like that since the first time I saw it. Doesn't leak.
Make sure you line up the "washer" on the back of the caliper pin so it fits flush with the caliper.
Once you have that bolted in, this is what you will see.
Tire reinstalled. Angle is probably a little different, but you can see more rotor now.
Tighten and retorque lugs. Then do the other side. My hand brake was just starting to hit 3 clicks so I adjusted the rears a little.
Once you finished, start the car up, keep the hand brake on and do not put into gear. Pump the brakes a few times and you will feel the pressure building back up. Then take it for a test drive to see how the brakes feel and listen for any noise. Be gentle on the brakes so they will have a chance to seat and break in.
Now for the impressions, The old pads had about 36K miles on them and were close to the indicators. Old rotors had no scaring of any kind, but I was starting to get a little steering wheel shake again. So I knew brakes were in order. These new brakes with the SS rotors feel great. Since the cost by acquiring the parts on EBay verses a parts store was much better, the entire cost of part was under $150. I personally think this a great upgrade. Time will tell for any other issues, but highly recommend this to any HHR or Delta II platform owners.
Can't remember who did this first, but you know who your are. A great big thanks for this info.
One note, since you have the tire off, it's also an excellent time to check your links, ball joints, etc. Just grap and see how they feel. Mine had no give. Also a good time to check for hub play, these hubs are new with about 10K miles on them.
Not sure if the mods want to make this a sticky or not.
solman98 is offline
Old 09-22-2012, 03:40 PM
ChevyMgr's Avatar
Nice!
ChevyMgr is offline
Old 09-22-2012, 03:56 PM
swerv0428's Avatar
Nice write up!
swerv0428 is offline
Old 09-22-2012, 05:45 PM
nrvous1's Avatar
Good stuff.
Will this setup work with stock 1LT 16" steelies?
nrvous1 is offline
Old 09-22-2012, 06:14 PM
solman98's Avatar
Good question, but looking at the space I still have between the caliper and wheel, I'd think it would clear 16's also.
solman98 is offline
Old 09-22-2012, 06:31 PM
Nice how do they stop ??
SS fan is offline
Old 09-22-2012, 06:37 PM
solman98's Avatar
I just did a quick run around the nieghborhood. Feel great. Not sure if I'll have it out tomorrow, but I'll find out Monday going to work.
solman98 is offline
Old 09-22-2012, 06:53 PM
A Crazy Canuck's Avatar
Hey, nice job.
Just a though on the rubber material on the caliper. That is not a seal, but a dust boot. If you get brake dust on the piston and then force that piston in, you could damage the seals. Then..it will leak...lol
I would replace those boots the next time you do your front brakes....or at least take them off and clean the piston before using the clamp to push the piston in.
I made this mistake on my chev express and it leaked until I finished installing my new pads and seated them by pressing the brake pedal.....the piston cam back out to where it was clean.....whew.
Cheers.
Corey.
A Crazy Canuck is offline
Old 09-22-2012, 07:02 PM
VinceP's Avatar
Good stuff.
I would be interested in knowing this for sure also. Sounds like a great upgrade for my LS Panel.
VinceP is offline
Old 09-23-2012, 12:33 AM
solman- Great write up & pics.. Nice up-grade
sleeper is offline
Quick Reply: SS rotors on standard HHR
