SSC Springs
Old Apr 30, 2012 | 09:29 PM
  #31
Think yours is fe3. The 5 is stiffer, but refined, compared to pedders.
Old May 2, 2012 | 04:38 PM
  #32
zap-mann's Avatar
I have the FE1 and the ride is OK. what will going to the FE5 with CM cobalt springs ride like in comparison?
Old May 2, 2012 | 05:26 PM
  #33
chefhhr's Avatar
How much did you trim from the bump stops? CM doesn't offer any instruction with the new springs. I may call ray tomorrow and ask them.
Old May 2, 2012 | 05:57 PM
  #34
moonsign's Avatar
As posted by Shroogis earlier: The springs rates for a Cobalt is just over a 100 lbs. lower that a HHR-SS. That makes the cobalt spring softer, will ride softer, but not handle corners as well. The cobalt spring in a HHR-SS is sure to make it ride lower.
A 100 lbs. difference in spring rate is a lot, and will definately affect the handling. "Moon"
Old Dec 16, 2014 | 11:00 PM
  #35
breds2k's Avatar
Hey guys just want to revisit this, anyone with the cobalt ssc/cm springs, how do you like the handling?
Old Dec 17, 2014 | 12:55 PM
  #36
prod's Avatar
They are a good moderate upgrade from the stock ls/LT springs. They are a bit lower and stiffer but still fairly comfortable. Combined with a rear anti-roll bar they make the hhr handle like amore performance oriented vehicle.
Old Dec 17, 2014 | 01:50 PM
  #37
the_shmoo's Avatar
X2
Well worth the install, great improvement in handling when combined with the rear sway bar. And easy to do.
Old Jan 20, 2015 | 04:58 PM
  #38
Cat Man HHR's Avatar
I've tried a couple of GM part websites, they tell me the Cobalt SS/TC rear springs are on national back order.
Want to use the p/n 25821162 for my SS.
Franco Fanfuria
14
Apr 6, 2010 10:06 PM
capp002
May 3, 2009 08:12 AM
