SSC Springs
As posted by Shroogis earlier: The springs rates for a Cobalt is just over a 100 lbs. lower that a HHR-SS. That makes the cobalt spring softer, will ride softer, but not handle corners as well. The cobalt spring in a HHR-SS is sure to make it ride lower.
A 100 lbs. difference in spring rate is a lot, and will definately affect the handling. "Moon"
They are a good moderate upgrade from the stock ls/LT springs. They are a bit lower and stiffer but still fairly comfortable. Combined with a rear anti-roll bar they make the hhr handle like amore performance oriented vehicle.
