Suspension, brakes, and hubs question.
Old Jan 25, 2015 | 09:48 AM
  #81
gio89kid's Avatar
Well I have the rear breaks adjusted recently, and now they are working fine. And was told they have good life left, but I'll check them when I can.
After I finish the work in the front, I'm going to look into changing the bushings in the rear suspension. Do you know of a thread on here that has a step by step how to?
Old Jan 25, 2015 | 11:24 AM
  #82
Check your PM.
Old Jan 25, 2015 | 03:16 PM
  #83
Blue_SS's Avatar
Where's Donbrew1 when we need him?
Actually, Gio, you are being a little vague. If you want help, you need to provide more details. If not, then you can just carry on and not try and get people to chime in and try and guess at what you are facing and what you ought to do.
Old Jan 25, 2015 | 05:04 PM
  #84
gio89kid's Avatar
Well my car has over a 100000 miles on it and started to shake, in order to fix the shaking I replaced the hubs and resurfaced the rotors with new pads. Now that the shaking is gone there is squeaking coming from the front and rear of the vehicle. So I changed the shocks all around and the front sway bar end links. Now all there is left to change is the front lower control arms and rear axle bushings and it should ride quiet and perform like new.
Each part in have purchased, for a much cheaper price I might add than having someone put them in and with free labor from myself, has made noticeable differences in drive performance and less squeak. After lower control arm change there should be no noise coming from the front what so ever.
Yes my questions might seem all over the place, but it's because I have been figuring things out as I go along and run into new things that I replace.
Old Jan 25, 2015 | 05:06 PM
  #85
gio89kid's Avatar
Everyone here has been doing a great job in answering my questions.
Thank you very much :)
Old Jan 26, 2015 | 06:41 AM
  #86
Did you replace the front sway bar bushings, they are a source of squeaks and rattles
Old Jan 26, 2015 | 09:42 AM
  #87
gio89kid's Avatar
No I did not, I'll check those after the lower control arms.
Old Feb 17, 2015 | 07:52 PM
  #88
I moved some of the new stuff into a new thread. Here: https://www.chevyhhr.net/forums/main...erature-53088/ and here : https://www.chevyhhr.net/forums/prob...control-53089/
This one is now closed.
Wifes07LT
10
Aug 4, 2015 03:39 PM
Revolution is my name
Apr 19, 2014 10:05 AM
SoCalMiniSS
Jan 25, 2013 12:58 AM
working on it
Aug 1, 2011 03:40 PM
STLracerX
Jun 4, 2010 10:49 PM
