Suspension recommendations for 1LT, 1LS, and 2LT HHR's
Well, I have an HHR 1LT (stock ... everything) 2008 with the "comfort ride suspension" package. Basically, in comparison with everything else I've driven (except a lifted/diesel truck and a mack 7000-series) this thing feels/handles like a tank. Tires are all BFG's, and ones I used on my '95 mx6 I had when I raced autocross so it's not the tires at all. I was wondering if anyone knows of any upgrades that work, etc. since all the stuff I've found is stock parts, no aftermarket shocks/springs (all I really think this thing needs to get it to turn somewhat). Of course, if anything else has really worked well to get these things to handle/turn, well, lemme know!!!
I figured, since there's no such "generalized" suspension/performance thread, well, I'd start one so others with similar questions can come here to find the answer. Of course, if there's another thread that already answered this, a link would be appreciated!
- Jake R
- Jake R
I leveled my Panel with Cobalt rear springs, lower CG; then added a TTR rear sway bar.
Now I can push it thru thru twisties & it stays flat & planted.. No more like riding a stagecoach..
I'm sure you will get many other options also..
Thanks!
Sounds like a plan ... I was considering selling this car b/c I am just so frustrated by the total lack of cornering (and TCS & SC & ABS is a PITA for me too...). Gotta find something to keep 'er planted.
- JR
- JR
My 2LT "sport" suspension (FE3) is nice the way it is for handling.... lowering and sway bar would improve it I'm sure but with lighter tires and wheels (16" Euromax 612/Dunlop Direzza) this thing likes the twisty bits
Peddlers, Eibach & Goldline make lowering springs too.
Use the Search function, there are loads of people's choices for their rides..
My 2LT rode & handled well too. But stock the rear end was up too high for me.
Just didn't care for the body roll in hard turns.. Now that is Gone !!!
Like Greybeard999, my 2008 2LT Panel has the "sport" suspension and isn't too bad.(NO it's not a race car suspension) But for what the HHR IS, it's OK.
I did just buy a set of Goldline Rear Leveling Springs, used, from a member here so that may improve it some.
I bought them more for the Looks. I'm not hauling heavy loads in the back, so I don't think I needed the extra height, and I just wanted the Level look over Lowering all 4 corners.
The rear swaybar will give the most improvement in cornering, I would try that first.
If you still want more, go for a set of stiffer lowering springs like sportlines or pedders. You could also go for better shocks and stiffer front swaybar from the SS.
If you are serious about going to the track though, nothin beats a set of coilovers instead of the springs/shocks.
Got the "sport" suspension as well........The only correction to Gb's comment is that springs and sway bar DO improve the handling.
Riding on GLs and Progress Tech sway bar for 3+ years now.
