Suspension Work
Old Jan 17, 2011 | 03:00 PM
foolmoon_design's Avatar
Suspension Work
Just scheduled to have shocks, struts, springs(pedders), tires, and camber kit done at the dealer(includes alignment). they think 3.5 hours should cover it? any objections. I'm looking at about $1,800 parts, labor. That includes tires. Eagle GT's.
I was gonna put the MX's back on but they wanted $291.00 a tire!
Old Jan 17, 2011 | 04:17 PM
Eagle GT's are nice tires..... Like the way mine work!
Old Jan 17, 2011 | 04:42 PM
Rod Run's Avatar
Holy crap!!!!
That just sounds like so much money. How much of that is labor, over $400.00?
Old Jan 17, 2011 | 05:47 PM
Just under $400 for labor. They estimate alot longer if done piecemeal. On the plus side if the shocks and struts are still good, I may hold off on those and save some.
Old Jan 17, 2011 | 05:56 PM
THE BATMAN's Avatar
Seems like a good deal to me .
Old Jan 17, 2011 | 06:17 PM
I was going to tell you the F-1's are a better and longer lasting tire till I went to Disc. tires web site the eagles are 161 ea. and the F-1's are 237 ea. I bought mine in Nov. and paid 172 ea. and got a 80.00 rebate from them damn thats what you call tire inflation,isn't it ? Are you changing the struts & shocks cause they are bad ? If they are ok you would really like the difference the TTR upper mount makes. I got a bid from a good alignment/body shop of 500.00 just to install the springs & align so that price isn't bad from a dealer no less. Want a full report when you get back from the first test romp
Old Jan 17, 2011 | 09:11 PM
Rod Run's Avatar
That's not bad a bad price then. I guess I'm just lucky that I am able to 95% of my own work
Old Jan 17, 2011 | 10:03 PM
RFT's Avatar
RFT
Something of note: you might want to have them check the speed rating on that $291 tire. That's probably the V speed rating and ask for a price on the W rating. I had to replace one, and the part numbers were the same at that time between the two speed ratings. However the W was priced $130 less than the V.
Rob
Old Jan 18, 2011 | 06:28 AM
Rob
I had the service dept check. The tech was the one who steered me away from the MX's. They are the OE tire rated to 168MPH. W rating. For some reason the Eagles are a Z rated tire 186mph, for a whole lot cheaper.
I'm not doing the $300+ tire route again. Years ago, I put a set of Dunlops on a 300ZX Twin Turbo.....ready........$1,600! Boy did they see a sucker comming. I think I got maybe 15,000 miles out of those tires. They had such a soft compound on them that you could cut the tire with your fingernail, and a burn-out left tripping hazards on the ground-literly caked rubber!
Old Jan 18, 2011 | 08:34 PM
RFT's Avatar
RFT
Sorry, was trying to help if you wanted to get the MX's. I wouldn't have mentioned it otherwise. I won't be getting the MX's when time to replace mine. Not because of cost, just not happy with the tire.
Jeffharden1
Aug 25, 2014 01:50 PM
HHRLT
Jul 23, 2013 02:58 PM
JMichael
Oct 23, 2012 05:19 PM
sethwas
Sep 8, 2009 09:35 AM
