Sway Bar Bushing 10mm bolt stuck
I am in the middle of replacing my sway bar bushings. My passenger side was relatively easy. However, the drivers side 10mm bolt does not want to budge.
There is not enough space to get a 15mm wrench on the top nut. I tried a breaker bar and it started to round out the bolt, so I stopped.
Any advice appreciated
The book says to loosen the big bolts the go through the LCAs then drop the frame down an inch or 2.
Here is one of the threads on the subject with a few ideas. Basically being inventive.
https://www.chevyhhr.net/forums/brak...ushings-35868/
I was able to get the nut and bolt free.
I found a 15mm box end wrench that was just small enough to fit over the nut and get a 1/4 turn on it. That was enough to finish it off with the 10mm socket without rounding out the nut.
so sway bar bushings and end links have all been replaced!
Thanks for the replys!
pstar
13
Aug 22, 2019 03:21 PM
Snoopy
12
Nov 27, 2014 11:05 PM
1970judge
Apr 3, 2012 11:07 PM
