Sway bar bushing bracket bolts????
Old Nov 7, 2018 | 06:36 AM
HHRerrr's Avatar
I've never had much luck with those tin bolt retainers, especially in tight quarters like this is, but I'll give it try. This sure is a cluster thanks to some brilliant design work....or is it the lack of?
Old Nov 8, 2018 | 10:28 AM
HHRerrr's Avatar
Got the passenger side bushing changed out. Tried moving the tin bolt retainer up with some success but not enough to get the nut off. Tried loosening the LCA bolt but seemed like it would have taken a lot to get the nut off. The 'bigger hammer' method is what finally worked for me. One thing I noticed once the old bushing was out (it wasn't in too bad of shape actually) was that the distance from the bottom of the bar hole to the bottom of the bushing was about a quarter inch more on the new poly Moog bushing. That struck me as a good thing.
I do have one more question. Will it be easier to change out the drivers side bushing?
Old Nov 8, 2018 | 11:51 AM
No!
Old Nov 8, 2018 | 11:59 AM
X2, no, except now you know the wrenches you need!
ImNewHere
Nov 8, 2018 08:44 AM
macarchie
Aug 4, 2014 08:50 AM
DreamHHR
Nov 23, 2012 05:10 PM
1970judge
Apr 3, 2012 11:07 PM
hurst2001
Sep 21, 2010 09:44 PM
