sway bar for HHR
Old Jun 1, 2011 | 07:38 PM
  #31
jay loukakis's Avatar
sway bar
Is that the same as Progress Tech. ??? (these guys.... http://www.progressauto.com/ ) I can vouch for that bar, it's solid construction and works! You won't break that one.
I have their lowering springs front and back, I went with them as they lowered more then the others, their bar is 22mm which is less than the others that are 25mm, but with my driveing it wont make a diffrence, I sent an E-Mail to Eibach and advised them whatI was going to do, so that is what I will do next wek.
Old Jun 1, 2011 | 08:40 PM
  #32
Their bar is performance matched to the stock front bar and works as a system. Bigger is not always better. Just do it, with their springs already installed you will have a slot-car!
Old Jun 3, 2011 | 02:43 PM
  #33
If Eibach was smart they would have bought a bar from Proggesive Engr. 40 miles from them and offered to install on my HHR, as I will buy from Proggesive and throw the broken on Eibachs front door. Piss poor marketing as that was my background.
Old Jun 3, 2011 | 03:13 PM
  #34
moonsign's Avatar
My 2 cents:
For the ones that think a bigger bar is not the way to go, I have to raise the B.S. flag.
First any quarter inch increase in the thickness of the bar, puts four times the amount of force on the bar in a turn.
I have a OTTP bar, one inch and a quarter[most other bars are one inch].
I have track time on this bar, and it plants the rear hard, and keeps it planted. Keeps inside wheel planted, and it does not lift, and does not make the front end push.
I have run this bar for about a year now, and it works. and will not break.
Want the ultimate in cornering, Pedders springs, and OTTP "Hardcore" bar, will do the trick. "Moon"
Old Jun 3, 2011 | 03:18 PM
  #35
JoeR's Avatar
Honest and factual answers to "junk" sway bar issues on this sorry forum will get deleted.
Eibach has acknowledged their design error, where the stress is concentrated at the point where the rear mounting bolt hole "may" result in the bar breaking at that point, with documented failures. They are currently redesigning the bar, bit are estimating late July for the new design.
Meanwhile, Progressive and the "other company with the 1" copy" that makes a bar with the same lame design with low carbon steel (1020, which is NOT suitable for this application!) have seen numerous issues with permanent deformation due to poor materials not suited to the application!
Until the various companies update to better designs and materials, I can only recommend going with Powell RaceParts rear bars.
Old Jun 3, 2011 | 04:31 PM
  #36
how to contact powell raceing?
Old Jun 3, 2011 | 08:31 PM
  #37
moonsign's Avatar
The Powell bar is the same bar that OTTP uses. Comes in either one inch or bigger, inch and a quarter. You want a Powell bar, contact OTTP[OverTheTopPerformance]. I'm using the Inch and a quarter bar, called the "Hardcore". It works for sure. "Moon"
Old Jun 3, 2011 | 10:22 PM
  #38
I sent an E-Mail askeing for info, part #, how much? shipping how to get an answer.
Old Jun 4, 2011 | 08:30 AM
  #39
Question? why is Eibach designing a new bar for the HHR when this last year of mfg.? Ive had 2 break in less than 5000 miles, they will not respond to an E-Mail?
Old Jun 4, 2011 | 12:25 PM
  #40
anyone have a photo of the OTT rear bar?
