Violent shaking while braking, one rotor only
Old Jun 8, 2016 | 09:09 AM
Agreed on the bolt not being torqued correctly, plausible cause of damage!
I agree the rear brakes , in a drum rear brake HHR not adjusted correctly causing brake judder.
I have found over the years some brake shake caused by a toasted rear lower control arm bushing, even after I swapped in the larger diameter SS non Brembo rotors and caliper brackets.
Old Jun 9, 2016 | 06:36 PM
Blue_SS's Avatar
The caliper brackets are just fine, and don't flex. That is the first time I've ever heard that one, and I do Chassis warranty at an OEM!
It sounds like your bracket might have been loose.
csatech
Jun 17, 2025 04:16 PM
DMarotta
Dec 2, 2014 10:24 PM
del1933
Nov 17, 2013 04:11 AM
2010 hhr
Dec 18, 2011 01:08 AM
GRUMPEE
South Pacific
22
Apr 8, 2010 12:40 AM
