Violent shaking while braking, one rotor only
Agreed on the bolt not being torqued correctly, plausible cause of damage!
I agree the rear brakes , in a drum rear brake HHR not adjusted correctly causing brake judder.
I have found over the years some brake shake caused by a toasted rear lower control arm bushing, even after I swapped in the larger diameter SS non Brembo rotors and caliper brackets.
DMarotta
Dec 2, 2014 10:24 PM
del1933
Nov 17, 2013 04:11 AM
