2007 hhr automatic transmission
Old Jul 17, 2012 | 10:25 AM
donald cole's Avatar
i have found the transmission plug on top of the tranny to fill, it is black and threaded.
i cannot find the check plug. what the diagram points to on tranny is some sort of sensor on the tranny. am i missing something here?
Old Jul 17, 2012 | 06:06 PM
Augmented78's Avatar
There is no dipstick, the transmission is a sealed system.
Old Jul 17, 2012 | 06:57 PM
swerv0428's Avatar
Thats correct it is a sealed unit but there should be a check plug on it. Havent ever done mine. I may be wrong but i thought the check plug was also the plug to fill. i may learn something here too.
Old Jul 17, 2012 | 07:00 PM
That is not the sensor that the arrow points at, it is that small bolt. It is 10mm I think. There should never be a need "under normal conditions" to check the A/T fluid level. Look under the car for puddles, and on the bottom of the trans for drips. Trans fluid does not evaporate.
Old Jul 17, 2012 | 07:53 PM
swerv, I believe there are 2 plugs on the underside. One being a check plug and the other being the fill plug.
Old Jul 17, 2012 | 07:59 PM
swerv0428's Avatar
There may be. Havent dome mine. I couldnt remember. Thanks though
Old Jul 17, 2012 | 08:10 PM
my check level plug is on the back side half way up the trans, check it on level ground only or you will be over full or running low!
Old Jul 17, 2012 | 08:32 PM
Car level, engine running, tranny temp 104F; then remove plug to check for a drip/no drip. Level and engine running, or you will lose fluid!
Unless somebody has installed an after market pan with a drain there is no drain. On a stock trans there are no plugs on the bottom.
The plug is near the axle. If I remember correctly (highly possible 180 degrees wrong) on the passenger side.
The "fill" plug is actually a vent, and comes off by hand, located on the driver side top of the trans.
Old Jul 17, 2012 | 10:50 PM
to the forum Donald!
Give this thread a read. Just click the link below.....
https://www.chevyhhr.net/forums/maintenance-upkeep-50/checking-changing-transmission-fluid-28917/
donbrew
22
Mar 3, 2024 08:06 AM
Lone Ranger
Mar 17, 2014 09:43 AM
humbledservant
Apr 27, 2012 10:44 AM
sbishop1331
Dec 28, 2009 06:40 PM
JoeyFeduka
2.0L Performance Tech
13
Nov 5, 2009 07:50 AM
