2010 Auto Trans Issue
Old Apr 9, 2024 | 04:22 PM
Psypher56's Avatar
My 2010 will only work in reverse. When I put it into any drive position, nothing happens. It was suggested to drain and flush the trans. There are no codes showing for the trans. When I drained it and took off the pan, I discovered one of the oil feed lines had a loose end and is no longer soldered. Could this be the problem?
Old Apr 9, 2024 | 06:37 PM
Yes, the fluid transfer pipe assembly is the issue
this includes a part number
GM 24202349 4T40E Automatic Transmission Forward Clutch Low and Reverse Band Lube Pipe
JimW337
12
Feb 14, 2021 03:04 PM
TomR_here
Apr 29, 2016 03:48 AM
andyb
Nov 13, 2015 12:27 AM
pbatmen
Jul 12, 2012 10:54 AM
woodchuckd11
Maintenance and Upkeep
Mar 3, 2011 12:48 AM
