The automatic to manual swap thread
Old May 15, 2020 | 05:58 PM
Don't have ABS??????
Old May 15, 2020 | 06:01 PM
I remember reading on the Cobalt forums, some were snapping axle shafts when they upgraded their LSJs.
Old May 15, 2020 | 08:53 PM
OshawaHHRss's Avatar
no, i have no vss, abs, or esc. Dont really need any of that stuff anyways. I use gps for speed and it doesnt bother me not having esc or abs
Old May 15, 2020 | 08:56 PM
i suspect that might have been a driver mod issue. Full send while wheel hopping. I might use a vue intermediate shaft and get dss to make me a custom passenger side axle. Id rather run base model axles than dss though
Old Nov 10, 2021 | 10:43 PM
Scott Fitzgerald's Avatar
How do I remove manual pedal setup??
yes I realize thread os old but if theres a chance to get an answer l try it. Currently doing a auto to manual swap . The dash is completely out but can't figure out how to remove pedal assembly. Any help is appreciated. Thanks
in advance
Old Nov 11, 2021 | 07:42 AM
Does this help?
Old Nov 11, 2021 | 07:51 AM
Please read and look at the photos in post #1 , as you’ll see he does say he removed the dashboard and the drivetrain to remove the pedal assembly. You can also send a PM to the OP and ask questions.
Old Nov 11, 2021 | 10:57 AM
You don't need to do all of that to remove the pedals; You do need to do it to remove the plate they are mounted on to replace it with the one that has a spot for the clutch pedal.
Old Nov 12, 2021 | 01:57 PM
Automatic to manual trans swap
Yes it sure does help thank you for posting the picture of clutch pedal assy.. And the plate that it mounts to that's where I was getting lost at. Thanks again for quick response now to cancel my weekend plans and get this thing done
Old May 16, 2022 | 08:02 PM
that plate is on back order iirc.
