Automatic transmission issue…
Old May 19, 2024 | 04:52 PM
Gearhead1's Avatar
Hmm…
Ok…I agree with all that. What would be very useful info would be diagram of transmission connector to solenoid circuits…that way I could test resistance thru solenoids
Old May 19, 2024 | 07:48 PM
Fourth time :THERE IS A LINK IN MY SIG TO FREE SHOP MANUALS.
Since it seems to be arduous to look there here it is: https://charm.li/
Or if you don't like free stuff go to helminc.com a spend a fortune on the same thing.
Old May 19, 2024 | 09:31 PM
Gearhead1's Avatar
Thanks…
But actually I believe I found what I needed. I found diagram with which pins go to each solenoid. And what their ohms should be.
Looks to me like pin “A” & “E” are for solenoid 1-2 (the circuit or solenoid according to the DTC
Old May 19, 2024 | 09:44 PM
Free is too much to pay.
Old May 19, 2024 | 09:53 PM
Gearhead1's Avatar
Lol….
No….I have manual I bought long time ago. Only reason I asked is because…lot times you get valuable first hand experience info.
Thanks,
Old May 20, 2024 | 06:11 AM
Did you see , fastsuv’s thread?
Old May 20, 2024 | 06:30 AM
PulpFriction's Avatar
Throw in the 1-2 solenoid and button it up. 10/1 odds you’ll be done.
Old May 20, 2024 | 07:31 AM
But while you have the subframe down and the side cover off, change all the solenoids
Old May 21, 2024 | 03:09 PM
Gearhead1's Avatar
Sure enough….got valve body cover off and 1-2 (1st & 4th) solenoid melted. At first glance wiring harness appears ok but Im going to look it over good and test it electrically
Old May 21, 2024 | 03:49 PM
I told you, solenoids, I have a gift! Lol
