Automatic transmission issue…
I can see why….that thing will trick you ….lol
well got it all back together and short test drive…no leak far as I can tell on that short distance…all gears seem to be working. So I morning I will see about oil leak ….oil hanging on belt tensioner arm and everything below that wet. So I left the inter fender section off so all I have to do is take right wheel off….then air box and wooly worm
Oil leak
No, no lights. Filter cap dont seem to be leaking…all on chain cover…,think it is the front crank seal and oulley slinging it up on tensioner arm. I washed it all off best I could…gonna drive some and re-check. (100,000 milesish since new seal)
I need to get front end aligned…question is…if I do need to change that seal, can I do that without messing with the suspension? Looks like I can.
Thanks
Thanks
