Automatic transmission issue…
Old May 23, 2024 | 08:20 PM
  #31
That problem surfaces at least once a month, sometimes a few times a week. Just about every time someone pulls the fuse box.
Old May 23, 2024 | 08:38 PM
  #32
Gearhead1's Avatar
I can see why….that thing will trick you ….lol
well got it all back together and short test drive…no leak far as I can tell on that short distance…all gears seem to be working. So I morning I will see about oil leak ….oil hanging on belt tensioner arm and everything below that wet. So I left the inter fender section off so all I have to do is take right wheel off….then air box and wooly worm
Old May 24, 2024 | 06:47 AM
  #33
That tool is a two leg bearing puller.
Old May 24, 2024 | 09:00 AM
  #34
Gearhead1's Avatar
Oil leak
No, no lights. Filter cap dont seem to be leaking…all on chain cover…,think it is the front crank seal and oulley slinging it up on tensioner arm. I washed it all off best I could…gonna drive some and re-check. (100,000 milesish since new seal)
I need to get front end aligned…question is…if I do need to change that seal, can I do that without messing with the suspension? Looks like I can.
Thanks
Old May 24, 2024 | 03:58 PM
  #35
Oil pump and seal
Old May 24, 2024 | 04:01 PM
  #36
Gearhead1's Avatar
Checking into that now
Z32RB
Mar 22, 2023 08:31 PM
guppy
29
Sep 11, 2018 10:01 AM
1ksprint
Aug 18, 2015 03:52 PM
tpaul
Jan 22, 2014 10:10 AM
