Clutch fluid leak at junction to transmission
Old Nov 4, 2017 | 08:31 PM
Never had mine apart but is that a groove for an O-ring ? Or for the clip.
Maybe an O-ring goes on the metal part. Look in the receiving end of the block for tapering where an O-ring would seat.
It's got to have something that seals it since it's a hydro pressure line.
EDIT. Adainc. Where is part #23 ? Is something missing ?
Old Nov 4, 2017 | 08:35 PM
Randy. Don's 2nd pic can't be the MU3. Look again. Same trans as his 1st pic.
I think the bleeder threw me off. Well, we have a diagram now
Old Nov 4, 2017 | 08:46 PM
I think the OP may be missing Part #23.
Old Nov 4, 2017 | 09:04 PM
That is just the sleeve that the nipple sits in, and it is present
You may be onto something with the missing O-ring. Other vehicles(Saab, for one) use this same sleeve, around a pipe with an O-ring.
But I can't find a pic of the part in this HHR configuration.
Old Nov 4, 2017 | 09:11 PM
By Jove, I think I've got it!!!
https://www.cobaltss.net/forums/prob...p-lost-281903/
So the nipple is part #7 in the diagram GM P/N 24422067, also sold by CED
Old Nov 4, 2017 | 09:24 PM
Yep, there it is!!!!
Seems like you have to pull the trans again.
Old Nov 5, 2017 | 08:03 PM
adainc's Avatar
think i can order the 24422067 pipe and sneak the seal off of it or do i need to put the whole pipe in.
Old Nov 5, 2017 | 08:55 PM
From the pics in the link I posted, it looks like you could. It's certainly worth a try!
Old Nov 17, 2017 | 09:25 AM
adainc's Avatar
Want to give a heads up on the solution. Ordered a couple new pipes to get the seal I needed. The existing pipe had some marks on it where the seal was so i cleaned that up as much as was possible and put in a new seal and the sleeve. i replaced the entire plastic unit with the seal on the existing pipe. It worked and i no longer have any leak. Big thanks to all who put their thoughts on the board, it saved dropping the engine out again. Thanks
Old Nov 17, 2017 | 04:30 PM
That's awesome!!
bad03xtreme
Maintenance and Upkeep
13
Dec 19, 2014 06:23 PM
redmom605
Aug 4, 2014 06:55 AM
bad03xtreme
Jan 23, 2011 12:52 AM
lilgorilla
Nov 24, 2010 12:01 PM
