Dome light and rear view mirror not working
I have an 08 HHR and the dome light switch was broken when got it and the digital on the rear view didn't work. I replaced the dome light completely but still neither work. All fuses good. Any other ideas to try
When you say "all fuses good" are you aware of the second fuse box; passenger side of the waterfall? Fuse #27 and the RAP relay #32. You may not have noticed that the Retained Accesory Power wasn't working if you didn't know you had it.
I have no idea what that "PCB relay" is.
Believe it or not; there are some DTC Bxxxx codes related to the dimmer and the interior lights. You would need an expensive Scanner to read body codes though, the over the counter kind usually won't read them.
My buddy has a snap on computer cabinet scanner. I'm gonna have him check it tomorrow I went out and looked. There is a #31 relay in it but no #32. And I can't find a place that looks like another relay would fit in it. Lol. I'm lost. I'll let him check it and run the scan on it
