Neutral switch?
Old May 20, 2024 | 06:51 PM
Gearhead1's Avatar
Neutral switch?
Is there a good link here on how to get the connector off….guess its the neutral switch on top transmission that the cable goes too?
Old May 20, 2024 | 08:38 PM
greg8453's Avatar
Click around.
Operation CHARM: Car repair manuals for everyone.
Home >> Chevy Truck >> 2011 >> HHR L4-2.4L >> Repair and Diagnosis >> Transmission and Drivetrain >> Sensors and Switches - Transmission and Drivetrain >> Sensors and Switches - A/T >> Transmission Position Sensor/Switch >> Service and Repair
Transmission Position Sensor/Switch: Service and Repair
Park/Neutral Position Switch Replacement
Special Tools
J 41545 Park/Neutral Switch Aligner
Removal Procedure
1. Apply the parking brake and place the control assembly in Neutral. The transaxle manual shaft must be in the Neutral position prior to installing the range switch.
2. Remove the shift control cable from the transaxle range switch lever.
3. Disconnect the electrical connector from the transaxle range switch.
Warning
Hold the transmission range selector lever while removing or installing the lever retaining nut. Failure to hold the lever can cause damage to the transmission internal park system components which could allow the vehicle to roll when placed in the park position.
4. Remove the transaxle range switch lever nut and lever.
5. Remove the transaxle range switch bolts and remove the switch.
Installation Procedure (Old Switch)
1. Make sure the transaxle manual shaft is in the Neutral position.
2. Align the flats on the transaxle shift shaft with the flats on the transaxle range switch and install the switch.
3. Loosely install the transaxle range switch bolts.
4. Insert the J 41545 as shown and rotate the switch until the tool drops onto position.
Caution: Refer to Fastener Caution (Fastener Caution).
5. Tighten the transaxle range switch bolts to 20 Nm (15 lb ft).
6. Remove the alignment tool.
Warning
7. Install the transaxle range switch lever and nut and tighten to 35 Nm (26 lb ft).
8. Connect the transaxle range switch electrical connector.
Note: After adjusting the switch, verify the engine only starts in Park or Neutral. If the engine starts in any other position, adjust the switch.
9. Install the shift control cable to transaxle range switch lever and verify proper operation.
Installation Procedure (New Switch)
3. Tighten the transaxle range switch bolts to 20 Nm (15 lb ft).
Warning
4. Install the transaxle range switch lever and nut and tighten to 35 Nm (26 lb ft).
5. Connect the transaxle range switch electrical connector.
6. Install the shift control cable to transaxle range switch lever and verify proper operation.
pro multis · About Operation CHARM
Aj1968
Feb 21, 2023 07:02 AM
mgkdrgn
Mar 5, 2016 08:50 AM
Sundance
Feb 25, 2014 09:11 PM
RAB
Aug 6, 2013 02:29 PM
cosmic1
Mods - Interior
Apr 2, 2012 08:37 PM
