R&R Manual Transmission
Old Oct 15, 2019 | 05:35 PM
fastsuv's Avatar
My 2006 1LT 2.4L 5-speed needs a new transmission. I have been driving for a year and a half with no second gear. Third gear is now gone.
I got a replacement transmission from a local junkyard for $300. It only has 8K miles on it.
I have already stripped off the driver side suspension, removed the axle shafts, and removed all the splash shields.
Is there any interest in me providing pictures as I go along for a how-to? I searched the forums and there is a written how-to from a few years ago, but no pictures.
I am hoping to have the job done in the next week or so.
Steve
Old Oct 15, 2019 | 06:30 PM
We love pictures! Thank you for offering to provide them.
Old Oct 15, 2019 | 10:41 PM
fastsuv's Avatar
Well, I got all the way to the point where I remove the cradle with the engine/trans supported by a tall jack stand. Unfortunately the passenger side cradle bolt (rear one that goes through the bushing) is just spinning because the nut is spinning.
What was the solution to that problem? I recall someone had the same thing happen to them. I can barely see the area of the nut with a dental mirror and it looks like the spinning nut is inside a metal cage of sorts?
Steve
Old Oct 16, 2019 | 01:56 AM
geg's Avatar
geg
the nut needs to be jammed
if you show a picture, maybe we’ll come up with a way
Old Oct 16, 2019 | 09:37 AM
Either stick something into the slot to jam the nut or cut the bolt.
Old Oct 16, 2019 | 09:43 AM
fastsuv's Avatar
I think I will cut the bolt head off, which will allow me to drop the cradle (along with the lower control arm). Then I will be able to see the cage nut better and see how to fix it.
The number I get for the bolt is GM 11589009.
I found what looks like the correct cage nut here:
Cage Nut 14mm
Steve
Old Oct 16, 2019 | 05:14 PM
Lotsa never seize on the new bolts.
Old Oct 16, 2019 | 05:34 PM
Blue_SS's Avatar
Yeah, like a tub of margarine. Dip everything before assembly...
Old Oct 17, 2019 | 07:41 AM
fastsuv's Avatar
While we are on the topic of no-seize, I need to buy more since I have used up my copper-based Permatex that I bought long ago.
Does anyone have a recommendation for a GOOD anti-seize?
The reason I am asking is that I have found that, in the last 10 years or so, many old reliable formulas for car chemicals have been replaced with "environmentally-friendly" ones that don't work nearly as well.
Steve
Old Oct 17, 2019 | 08:41 AM
Copper
https://www.permatex.com/products/lu...ize-lubricant/
I use this for higher heat applications exhaust manifold studs in cast iron, exhaust pipe flange bolts for instance
Aluminum
https://www.permatex.com/products/lu...e-lubricant-2/
I use this for suspension bolts, spark plugs in aluminum heads, studs in aluminum parts, I just used up my last bottle after about 10 years.
