Simple question.
Old Nov 2, 2021 | 04:09 PM
Antilord's Avatar
Omg 7th try to answer
Just plugged in maf,LCA seem good ball joints questionable. Now I just have a random purge code. Just need to figure which valve to replace. Still buying all my motor mounts soon as I can. Thanks for the help. Need to go search the electrical area as I have to questions in that area.. one last thing, 196k having the transmission fluid changed shouldn’t hurt the trans right? Feels like they burnt it some while the maf was disconnected.
Old Nov 2, 2021 | 06:26 PM
LCA rear bushings, may seem good but are dried out and crumbling, these were just a year old and 12,000 miles!
They wanted to do an alignment to fix the clunk!
The one in the right, it’s separated from the metal barrel the bolt goes through
you can change the transmission fluid and filter, it’s an easy job
https://www.chevyhhr.net/forums/main...ge-easy-42736/
Old Nov 2, 2021 | 08:02 PM
Antilord's Avatar
Thanks for the heads up. I can get full pair LCA cheaper than two ball joints. Now added to the todo list right behind the rotor set I have coming. Thank you. The idea of taking the trans somewhere was because a longtime mechanic friend recommended taking it to a shop. That way if changing the fluid messed it up it was on them. I remember some old GM trans would do that if they hadn’t been properly serviced for too long. But I thought the new sec and trans materials changed that. Only reason I was considering a shop. I am guessing I am right by your response.
Old Nov 2, 2021 | 10:13 PM
.If you post the code number we could help. Haven't figured that out, yet?
Old Nov 3, 2021 | 07:31 AM
Cheaper LCA’s? As in stamped steel LCA’s? Those are for Cobalts and lighter cars, not the HHR, our LCA’s are aluminium and there is a difference that will cause alignment problems with those stamped steel LCA’s.
So choose wisely! Not by price but by correct fit and material!
You don’t have to go to a shop to change transmission fluid and filter!
Old Nov 3, 2021 | 12:08 PM
Antilord's Avatar
I noticed mine were aluminum. Had to go look at the ones I had saves and sure enough they are stamped steel. Thanks for the heads up about that
Old Nov 3, 2021 | 01:24 PM
I hope you mean saved in your cart on a website!
Old Nov 3, 2021 | 02:31 PM
Antilord's Avatar
Sure did, otherwise am forgetful
PulpFriction
Nov 4, 2020 09:07 AM
Nasaathoff
Sep 19, 2020 07:16 PM
bpb355
Jun 18, 2014 06:32 AM
alexrckid
Feb 4, 2013 03:23 PM
mightymouse
2.0L Performance Tech
17
Aug 8, 2011 10:16 AM
