Trans hard shifting
Old May 14, 2022 | 07:55 AM
The solenoids are not "inside" the transmission, they are inside the bell housing. You just need to separate the trans from the engine enough to work on them.
Of course, GoOgle will provide part numbers in a second or 2.
Old May 14, 2022 | 07:58 AM
Shift solenoids are inside the side pan with of the transmission
Old May 14, 2022 | 08:01 AM
flstss's Avatar
I was watching a video on how to do it in this form and it looked like you dropped the driver side frame connector and pull the axle out and it was a cover there that the solenoids are behind. Does that sound right?
Old May 14, 2022 | 08:34 AM
yes
Old May 14, 2022 | 08:48 AM
heathenhhr's Avatar
semantics, as it still requires more disassembly than I feel comfortable with, going in thru the pan or going in the side makes no difference to me
and feel free to use whatever google search you want, I try to be helpful when I can since I have the exact same catalog that GM dealers have, but best of luck
Drivesfed
12
May 11, 2022 04:43 PM
fst100
Dec 9, 2021 07:39 AM
guppy
29
Sep 11, 2018 10:01 AM
Daves06HHR
7
Mar 2, 2017 12:17 PM
IgottaWoody
Feb 23, 2008 11:47 PM
