Fuel Economy - Hypermiling Dedicated to discussions on fuel economy improvements and related modifications.
BAD winter mileage
Old Jan 14, 2009 | 07:18 AM
Clevelandhhrss's Avatar
Originally Posted by catdaddy137
i just changed oil , put in synthetic, mpg is better. while on highway i try to go 66mph it is a "sweet spot" for my 08 2.4 auto panel. i drive 270+ miles 6 days a week. i still go faster sometimes. i am most always concience of my engine speed. i tryed old trick yesterday , it does not always work , but sometimes when taking off from a stop , while getting slowly up to speed i let completely off the gas , sometimes this will make the trans shift to the next gear sooner -decreasing rpms and the amount i spend at the next fill up.i have to fill up daily , you can believe i watch everything about my vehicle. the oil , the speed , and the easing up to speed , and letting off , all work. i have tried not doing any one og these things , and it did make a difference. i just purchased my hhr a month ago , so i do not know what it does in the summer. but i increased my mpg from 24 to 27.
:) Hypermiling....... Search "absurd mileage"
Old Apr 5, 2009 | 05:15 PM
masterchief1112's Avatar
had my good gas mileage back. and is even better. got 36.0 on the highway.
Old Apr 6, 2009 | 07:32 AM
mistermike's Avatar
Originally Posted by IgottaWoody
Blame Reformulated fuel...cold air and cold fuel makes for more power( a racers battle forever) a heavy foot makes it less.
BUT : extended idlying for warm-ups , different driving styles for bad weather..trying to do burnouts in the snow....running the heater while parking( those darn kids again-snicker).You know..fun stuff,that kills milage!
Technically you get more power per unit of air / fuel at higher temps. Cold air and cold fuel will increase charge density, resulting in more power at the bleeding edge, but the tradeoff is combustion efficiency. Much fuel is wasted to obtain the increase. Combustion efficiency increases with increased temperatures, but so does tendency toward detonation. A British firm made some injectors that had little heaters in the tips to help vaporize the fuel, and the efficiency increase was significant.
Old Apr 15, 2009 | 02:49 PM
catdaddy137's Avatar
fuel ???
how would i know if and when they change what they add to winter fuel??? i just gained 2mpg after changing to a lighter oil and addng some fuel system cleaner. i was just wondering if they may have changed the fuel at the same time i did this.
Old Apr 15, 2009 | 03:02 PM
warm weather was more noticable for me. according to a few chemists i talked to the only real thing they add to winter fuel is a little more ethanol. it absorbs water and will keep it from freezing.
tireman1554
May 8, 2008 11:25 PM
Sunburst Sam
Mar 29, 2008 08:21 PM
chasarch
Sep 18, 2007 11:55 AM
ljkuntz
Apr 26, 2007 11:46 PM
