1158125
Old Jan 11, 2024 | 04:01 PM
The printed circuit board must have a crack in it. If heat fixes the issue, maybe there are speedometer cluster repair shops that can fix that.
https://www.automotivecircuitsolutio...repair-service
Old Jan 11, 2024 | 08:00 PM
Why do you suppose you are required to enter a odometer reading on a change of title? Could it be a Federal consumer protection law?
I don't know what is meant by OD exempt.
only other person to work on this was a recall for ignition..
Did the problem start soon after that?
Since the lights work, but the information supplied by the ECM doesn't I would suspect connectors/pins, maybe in the ECM connectors.
Old Jan 11, 2024 | 09:37 PM
ManyMiles08's Avatar
Started years after recall.. everything works after warm up...I should reset the oil warning but keep forgetting to.
engine light is for canister between fuel tank and rear axle emissions thing.
tire psi light I pulled those out when changing to 15-inch wheels.
“Exempt” means that a vehicle’s odometer reading report is not required for a sale to take place.
Vehicle models from 2010 or earlier are exempt,
while those after 2011 will become exempt when they reach 20 years of age.
Old Jan 11, 2024 | 09:40 PM
Was thinking the same thing... might pull it apart & look for it... can't be much worse. still drivable I use a GPS speedo..
If it gives me to much trouble It'll become a 400hp V-8 on a s-10 chassis.. Already have that here...
Old Jan 12, 2024 | 08:51 AM
There is a place on ebay that offers speedo repair service for about $129.
Here is the NHTSA publication. I didn't know there was a 10 year limit, let alone the new 20 year limit.
https://www.nhtsa.gov/press-releases...e-requirements
Old Jan 12, 2024 | 11:19 AM
  #26
I saw a few of them on Ebay.. might msg them for details..
Old Jan 12, 2024 | 11:20 PM
  #27
tiapetra's Avatar
Originally Posted by ManyMiles08
Cluster has never been replaced or even removed till now..
will work fine after driving with heat on for a period of time..
being in Florida that's rare.. I do also have radio problems started with display doing
wild random things yesterday had a time of 4:96 music went out ages ago..
pulled dash to replace radio (had wrong connections) so visited cluster to check connection.
Mine did the same. Cold was 60° or colder. Would work when sun came out, then worse and worse over time until gone forever.
Speedo shop in Miami fixed it while I waited (couple hours).
And mileage is 100% legal if checking box "unknown mileage" on both title and Federal Odometer Statement form.
See my post here, hope it helps.
https://www.chevyhhr.net/forums/prob...09/#post943499
Old Jan 13, 2024 | 07:55 AM
  #28
Do you remember the name of the shop? a bit far but they might know someone near me... just north of Brooksville..
Old Jan 13, 2024 | 06:15 PM
  #29
tiapetra's Avatar
https://leospeedometer.com/
I drove there from Ft Lauderdale and waited for the repair.
