2006 HHR LT 2.2L - Manual - Cat Converter ?
Old Jul 21, 2022 | 06:39 AM
  #31
CC819's Avatar
We only drive it on the weekends to the local farmers Market …maybe 30 miles round trip on the weekends…just randomly threw the code.I have a OBD2 scanner which suggested the downstream 02 sensor or the cat.conv needs replacing.Are the Bosch sensors just junk out of the box ? I’m going to hopefully pull it apart this weekend if the cat.conv arrives on time.
Old Jul 21, 2022 | 06:54 AM
  #32
CC819's Avatar
Originally Posted by donbrew
There is a recall involving the programming TSB # 05-06-04-073 for the 2.2L giving false P0420. If the VIN is lower than 6S559494 it needs updated ECM firmware.
I was afraid you would say Bosch, they are a problem.
Here is a pdf of the TSB:
Attachment 47766
Im assuming that’s a dealer only job ?
Old Jul 21, 2022 | 07:47 AM
  #33
PulpFriction's Avatar
Won’t affect many HHR’s but wow, the whole thing is pretty interesting, not just the part about P0420.
“DTC P0420 Catalyst System Low Efficiency - The ECM has determined the catalyst efficiency has degraded below a calibrated threshold. The ECM may prematurely diagnose a catalyst failure before the catalyst has been allowed to run hot enough for a sufficient amount of time to burn off manufacturing coatings inside the converter. These coatings adversely affect the catalyst efficiency and the O2 sensor performance.”
Pretty sure “manufacturing coatings” ain’t the problem in this case though, 17 years later, lol.
  #34
If you have a correct VIN it might be free.. That is the last 8 digits.
Bosch sensors have a history of being junk. NGK/NTK makes the ACDelco/GM part.
Old Jul 21, 2022 | 08:38 AM
  #35
The TSB doesn’t mean the parts and labour are free, just a Technical Service Bulletin, to help the mechanic figure out what’s wrong
Old Jul 21, 2022 | 09:09 AM
  #36
geg's Avatar
geg
Originally Posted by greg8453
For the OEM to fail at that mileage is a warranty issue unless it was being driven with the flashing CEL. Unburnt fuel is a big killer of cats.
Do you have a public road permit? If yes, then no problem. Even if the exhaust is bad.
Do not take my words as a guide to action in US (I don’t understand your laws, maybe it’s punishable), but if it was my car in my country:
1. visit to a small auto repair shop, diagnostics with a professional scanner, detection of stored errors on the catalyst;
2. destruction in the on-board computer of all traces indicating poor exhaust or improper operation of the vehicle that killed the catalyst;
3. visit to a car dealer, initiation of the procedure for warranty replacement of the catalyst.
Old Jul 21, 2022 | 09:27 AM
  #37
If Your state does not require emissions inspection, it does not matter if the cat is good, bad or not installed. (Public road permit)
The federal warranty is 8 years/80,000 miles. Way too late.
The freeze frame data might be of some use figuring out the why it failed.
Codes don't "randomly" set. They set for a reason; the test failed.
Any shop that has access to GM Techline can perform firmware updates.
JimW337
Drivetrain (Excluding Engine)
7
Apr 25, 2021 09:47 AM
fastsuv
Oct 15, 2018 12:13 PM
TomR_here
Apr 29, 2016 03:48 AM
gamma-wes
May 17, 2014 10:13 PM
LT1GMC
Apr 6, 2008 08:08 AM
