2008 hhr eng pwr reduced
Old Feb 24, 2019 | 06:41 AM
Originally Posted by nu2HHR
Where can I check to see whichever engine it is? I bought this used.
Tell us the model. There are differences year to year as far as the engine codes listed in the glove box sticker.
FYI. 8th character in the car's VIN tells you what engine it has.
2.0L---M
2.2L---B
2.4L---V
Old Feb 24, 2019 | 07:08 AM
nu2HHR's Avatar
I also noticed that the power was restored after turning the vehicle off then back on. The ‘eng pwr reduced’ display went away. There is static build up on the vehicle too. When you touch the vehicle it shocks you.
Old Feb 24, 2019 | 08:43 AM
Before you tear into anything, go to an auto parts store and get a free battery load test. Often multiple codes are the result of low voltage. Get the actual numbers from the test and post them here.
Old Feb 24, 2019 | 08:46 AM
Cat Man HHR's Avatar
Where are you touching to get a shock on the car ?
Old Feb 24, 2019 | 08:53 AM
Your idea is good about the battery getting tested. But will that give codes for Multiple misfire and Throttle body ? Both of those I think can be related.
Never had it done but I thought AutoZone, ect. only used a generic scanner to get you into some sort of ball park for a code problem.
Old Feb 24, 2019 | 09:06 AM
Since we don't even know what engine we are talking about battery test is the first thing to do.
The throttle body is 4 bolts and an electrical connector. Relearn consists of idling for a minute turning it off then idling again; rocket science!
I really doubt the throttle body has anything to do with it. Since you also have transmission codes You should be looking at wires and connectors and fuses and battery.
A common cause of the P2544 is, in fact low system voltage.
Do you get repeated shocks from touching the car or just one then none on the second contact?
Old Feb 24, 2019 | 09:08 AM
My last battery, when it died , there where some codes , the alarm went off and voltage was 12.2 static and 12.9 running.
new battery 12.8 volts, 14.6 volts running.
Old Feb 24, 2019 | 10:25 AM
Don
Can you show where just idling is the relearn for the throttle body? Have to know.
Don't you think if the engine can't perform well the shifting can be affected ?
Did find this on code P2544. Open to discussion on it.
https://www.yourmechanic.com/article...by-conor-fynes
Old Feb 24, 2019 | 10:40 AM
nu2HHR's Avatar
According to the Catalytic sticker it says 2.2L
Old Feb 24, 2019 | 11:12 AM
Ok 2.2 but your bio says you have a 2008, that L on the left side of the sticker indicating model year, the 2.2 changed in late 08 for 2009 when it got VVT.
