3M tape?
Old 08-31-2006, 07:53 PM
Clarke33's Avatar
3M tape?
I was getting ready to install my aftermarket spoiler with 3M tape and noticed in the instructions they suggest using a 3M cleaner for the painted surface and a 3M adhesion promoter before applying the tape. All I was planning on doing was to clean each surface with alcohol then stick it on. Sounds to me like 3M is wanting to sell more stuff but on the other hand, I don't want the spoiler flying off at 80 MPH either. I did get the good 3M tape from a body shop supply house and they didn't mention anything about any of the other stuff. Anyone got experience with this tape?
Clarke33 is offline
Old 08-31-2006, 08:18 PM
The promoter makes a BIG difference. You should be able to get some form you local auto parts store. Come in bev-nap style pouches. One goes a long way!
GDZHHR is offline
Old 08-31-2006, 08:31 PM
courthousedeb's Avatar
Better safe than sorry Lee. I picked some up from NAPA for $1.69, but they had to get it from their warehouse, as they did not have it in stock at the store.
Check out THIS site. This is what the packet I bought looks like. They are only $.69 there, but then you would have to wait and also pay shipping.
courthousedeb is offline
Old 08-31-2006, 09:24 PM
DARK AGE 53's Avatar
For a spoiler I think I'd do as they suggest.
DARK AGE 53 is offline
Old 08-31-2006, 09:52 PM
Firewatcher's Avatar
Partially hijacking this thread
Speaking of 3M tape........does anyone have the 3M part number for the tape everyone is using to attach the metal scroll lettering to their hoods?
Firewatcher is offline
Old 08-31-2006, 10:04 PM
dan-d's Avatar
Alcohol tends to leave it's own film behind, it's a great cleaner but I would recommend using an adhesive promoter to clean away the alcohol film. 3M would like you to buy theirs, but any promoter will do the job. I usually use brake clean on a cloth to clean a surface instead of alcohol, then use an adhesive promoter. I've never had a spoiler come off yet....crossing fingers...LOL
dan-d is offline
Old 08-31-2006, 10:10 PM
cj krause's Avatar
you can get the tape in 1/2 inch and 1 inch widths at any of the auto parts stores. comes in a small and large roll. large roll is much better for the money and if you keep it cool, it lasts a while.
you will find it in the pinstripe accessory section usually.
this is dark grey w red backing. looks like a big red roll
cj krause is offline
Old 08-31-2006, 11:48 PM
dan-d's Avatar
cj, I don't think he has a problem getting the tape. The issue here is adhesion and prep work.
dan-d is offline
Old 09-01-2006, 12:01 AM
cj krause's Avatar
it was for this post
Old 09-01-2006, 07:41 AM
SCOOT's Avatar
Here's what I used... 2-sided 3M tape.
(I can NEVER!! get pic's to show in this forum... must need to be a premimum member...? I downloaded the pic titled *3M Tape* to the "Other HHR's" gallery.)
I used this for my chrome 'Chevrolet' scripting on the back of my HHR. I prepped the removed the OEM letters, prepped/cleaned the surface, flipped the emblem over and ground off the posts, stuck the tape to the emblem and pressed it on well*. I then used an exacto knife to 'cut' the tape out of/around the scripting (while still upside down).
Once complete - removed film to expose sticky that'd adhere to the vehicle... applied!
You can purchase this tape from any autoparts store throughout the country.
Hope this helps...
*Note, depending on where mounting, that the emblem 'may' need some slight bending (or arc) to accommodate curvature of the body panel. Do this ever so slowly/lightly to avoid cracking the chrome finish.
SCOOT is offline
Quick Reply: 3M tape?
