ABS light not on
Old Dec 10, 2008 | 10:04 AM
ChevyMgr's Avatar
Originally Posted by matts
Also, the guy said that it would not show up on the build sheet since ABS and traction control are built into a system together. Am I getting the run around?
Yes.
You might want to drive into their service department and ask them to show you the ABS module. It will be in plain sight by the brake booster. Yours will only have a master cylinder there.
Old Dec 10, 2008 | 06:35 PM
wxman's Avatar
He said that after talking to the service department, the light would only come on when the system is in use and probably will not come on during start up.
Just so you know, the ABS light is illuminated when I turn the ignition on.
I've got the LS base model with the only added option being "Enhanced Safety Package", which includes ABS and side curtain airbags.
Old Dec 10, 2008 | 06:51 PM
ChevyMgr's Avatar
The light at ignition start up indicates that the EBCM (Electronic Brake Control Module) is running self tests on the system. If everything is within parameters the light shuts off. If not it stays on and your ABS and Traction Control are disabled until repairs are made.
Old Dec 10, 2008 | 07:49 PM
wxman's Avatar
That's what I meant. It just goes on with all the other icons for the self test. Doesn't stay on... :)
Old Dec 10, 2008 | 08:52 PM
ChevyMgr's Avatar
purple people eater
Sep 17, 2016 01:07 PM
NxlKing2304
"How To" Tutorial Library
Apr 10, 2015 12:23 PM
venomlegionsHHR
Apr 11, 2012 04:42 PM
Kane2727
Mods - Exterior
Apr 2, 2012 10:46 AM
itschaboykenny
Feb 17, 2008 12:01 AM
