ACC Ignition Key Position Problem
Old Dec 13, 2018 | 08:43 PM
Look at the printing on the wire in the house. It is rated 600 Watts. Can you spell fire hazard?
Old Dec 13, 2018 | 10:32 PM
Silverfox's Avatar
20 amp circuit breaker
#12 copper wire. Cannot see wattage on wiring. #12 copper wire wattage allowed 1840
Leviton #9874 ceiling Ceramic bulb fixtures. Rated maximum 660W each.
4 separate fixtures with 150 watt GE soft white Bulbs.
Looks like I could go to 200W bulbs if I wanted too.
Battery install went like clock work. Vacuumed out all rear area. Checked PSI in spare tire.... 60lbs.
Cleaned up battery posts and female cable ends with 220 wet/dry sand paper.
Used 1" China Bristle brush to rid the posts and cables of sanding debris.
Put the charger on and let charge for 15 minutes to a full charge.
DONE.....
Time for bed.
SF
birdswitharms
Jan 2, 2018 05:54 PM
Benjamin
Dec 4, 2012 04:19 PM
ggoneprr
Dec 22, 2010 07:50 AM
c2vette
May 29, 2009 09:05 PM
Daverb
Mar 25, 2008 12:06 PM
