adjusting headlights
Old Aug 14, 2014 | 09:45 PM
skyline26's Avatar
ok so I need to adjust my headlights...my driver side is too high and im blinding people. I used the adjuster screw in the engine bay but there is no difference in level of light...what am i doing wrong? I turned it both ways like 10-15 turns each and its still the same
Old Aug 14, 2014 | 10:11 PM
My first question is why is just the drivers side too high ? If the adjuster screw has popped out of it's bracket, this may be the reason the light is now too high.
Haven't really studied the HHR headlight and adjustment system, but I have replaced and aimed many a headlight over the years in different vehicles. I've seen many broke tension springs, brackets, etc. that can effect the aim.
Old Aug 14, 2014 | 10:39 PM
There are a couple of pivot points inside the light that the reflector is attached to, don't know how they got loose if you didn't crack open the case. I have had to go back in and make sure they are seated properly, when building a set with projectors. I also had trouble adjusting them till I found the right tool.
Old Aug 14, 2014 | 10:46 PM
skyline26's Avatar
I have never taken the housing apart so it should all be intact. Ever since I put in HIDs the driver side has always been high. I've taken the housing off to make sure its seated properly and it is.
Shocks and ride height is fine.
How do we know of the screw adjust or has come off?
hhr06NJ
Sep 25, 2014 07:01 PM
tntwolt
Maintenance and Upkeep
18
Mar 29, 2013 03:00 PM
Alexwsilver2010
13
Dec 1, 2012 06:51 PM
laylowcustoms
Mods - Exterior
Mar 5, 2008 06:25 PM
john_a_basilio
Feb 1, 2007 07:07 PM
