Air in cooling system
Old Nov 10, 2016 | 08:14 AM
Trex08's Avatar
Still don't understand procedure. REmove bolt, then what, start engine, turn heat on, shut off, top off, what am I doing here? THis is like pulling teeth,
Old Nov 10, 2016 | 08:17 AM
Unless you want a faceful of very hot water that WILL cause 3 rd degree burns (real experience).
DON'T WORRY ABOUT THE BOLT! See post #5.
The coolant is about 200F at 15 psi, if you remove the bolt it will harm you.
The bolt is there for other applications, like oldblues Saturn.
Old Nov 10, 2016 | 08:46 AM
I've sent you a PM. BTW Don , Sweetie's ride is a Pontiac Sunfire GT, which has a pressure tank system same as the early 2006 HHR's and I suppose Saturns. The black hose would go to the fitting in place of the plug bolt
Old Nov 10, 2016 | 09:01 AM
I would not try the bolt removal as a bleeding method. You're just asking for a big mess with antifreeze getting on everything.
Either use the front end elevation method or take it to a shop and have them do it with the evacuation machine.
Fwiw. On the SS 2.0, there is no bolt there. There is a banjo style fitting with a coolant line that connects back around to the turbo.
Old Nov 11, 2016 | 12:22 AM
Excellent point on the Banjo Fitting George, it's not applicable in Trex08's case, but it can keep an SS owner from doing something dangerous to themselves...and their engine.
Two options Trex, get its nose up, or get to a radiator shop.
Old Nov 19, 2016 | 09:15 PM
Trex08's Avatar
Been a crazy week but I wanted to get back here and thank you guys for all the help. I burped her like a little baby it it def took care of the issue. You guys are the best. Still have a few little issues to solve with the blue flash panel until I get her on the road. Still driving the white panel until I sell it. Might wait till spring.
Old Nov 19, 2016 | 09:35 PM
Good to hear, party on !
RICK167448
Maintenance and Upkeep
May 4, 2011 04:36 PM
RICK167448
7
Jan 21, 2011 01:14 AM
skyeglen
Apr 26, 2009 07:51 AM
SSROADSTER
Jun 7, 2008 04:14 PM
