always use 5w30 oil?
I always use the recommended viscosit. You probably could use 10W30 in the summertime, but just check the users manual. It should state if other weights are acceptable and what temperatures you can use them in. If you don't use it in the car, it should work in your lawnmower. The lawnmowers usually call for SAE30 or 10W30.
Follow the manufacturer's recommended oil to use. Anything else can cause problems. And...every oil change...add SeaFoam...it is amazing!
http://www.seafoamsales.com/motorTuneUp.htm
For Peak Performance, Use SEA FOAM Every 2,000 to 5,000 Miles
A 100% pure petroleum product for use in all gasoline and diesel type engines, both 2 and 4 cycle. OXYGEN SENSOR SAFE.
Cleans dirty engine parts internally by removing harmful gums, varnish and carbon. WORKS AND PERFORMS INSTANTLY.
Removes moisture from oil crankcases and fuel tanks.
Stabilizes and conditions fuels. Use for engine storage.
Cure hesitations, stalls, pings and rough idle due to carbon buildup.
Helps pass emissions test. EPA Registered.
When Added to Fuel Tank
One pint treats 8-25 gallons of fuel (average 1 ounce per gallon).
- Cleans fuel injectors and carburetor jets
- Cleans carbon as you drive
- Lubricates upper cylinders
- De-ices and removes moisture
- Diesel full conditioner and anti gel
- Stabilizes fuel
You add it directly to both the crankcase and the fuel tank!
My father purchased a boat in 1971 that was made in 1947. It had twin Chrysler Flat Head Six engines. One engine was spewing out smoke. We poured some SeaFoam into the crankcase, restarted the engine...it coughed once, then purred like a kitten and no smoke. During WWII, SeaFoam was used by the US Navy and they said it made their engines run better and longer.
Directions: Add to crankcase when changing oil...add to gas every 2,000 to 5,000 miles, just like Deb said above.
You're supposed to change your oil if you put seafoam in it, not after you change the oil.
On css, a couple people have put it in there oil, vacuum line, and fuel tank. When they rev the engine afterwards, it smokes like crazy for a few minutes. They say it makes a noticeable difference though.
Here's one:
http://www.youtube.com/watch?v=mrHgvBSrsmQ
Here's one:
