Auto to manual swap
Old 02-04-2013, 04:17 PM
skyline26's Avatar
Auto to manual swap
does anyone know if someone has changed their Auto HHR to a Manual? Is it possible? any details on this?
thanks
skyline26 is offline
Old 02-04-2013, 04:41 PM
badassbowtie's Avatar
I don't know if anyone has done it, but you would need:
Manual transaxle/clutch
axle shafts?
new gearbox
computer/harnesses
and probably other nuts and bolts
also, I could be wrong but the engine is may not be in the same exact location as the manual.
Good Luck with the swap if you go thru with it
badassbowtie is offline
Old 02-04-2013, 04:43 PM
can you say.........Trade - In ?????
SS fan is offline
Old 02-04-2013, 04:45 PM
skyline26's Avatar
not for me, but a friend of mine wants to do this and trying to get some info on it before hand...i also think the rad would have to be changed as well..hes got the skills just trying to finalize the items needed process :)
Old 02-04-2013, 05:21 PM
Lucky's Avatar
The only practical way to do it is to buy a salvage manual hhr and start swapping parts. Shifters,clutch master and linkage,PCM,misc sensors,flywheel,ect it's a lot of parts and a lot of work but anything can be done given time and money.
Lucky is offline
Old 02-04-2013, 05:49 PM
....Clutch pedal and mounting hardware. Std trans brake pedal.(yeah it's different) and on and on and on-----
firemangeorge is online now
Old 02-05-2013, 11:24 AM
IgottaWoody's Avatar
Cost not justifiable...too many different parts not to mention the reprogramming (electronics) involved..not just a bolt in swap like ...the old days. Plus theres different gearing which actually falls under the reprogramming nightmare...trade it in..start over
IgottaWoody is offline
Old 11-04-2018, 11:18 AM
OshawaHHRss's Avatar
I know this is an old thread but I’m doing the auto to manual swap and it’s a lot cheaper and easier than everybody thinks
OshawaHHRss is offline
Old 11-04-2018, 11:25 AM
you just have to turn the transmission off in the tune. Changing the gearing doesn’t have anything to do with your tune with a m/t
Old 11-04-2018, 06:10 PM
Ohiocruiser's Avatar
With hhr it doesn't make any sense. Sell auto and buy manual.
Ohiocruiser is offline
Quick Reply: Auto to manual swap
